65 Front end upgrade Brake line routing
Kingspeedy2
Post by Kingspeedy2 »
I know this is shooting for the stars a little ,I have installed a new Total cost involved front end wit disk brakes and was wondering if anyone happens to have pics of the flex/steel line routing they utilized?
As an option on this site was a great pic of the front end of a 65 wit the wheel off showing the are and stock routing and bracket location .I just can seem to find it. Unfortunately a bunch of my disassembly pics died with a hard drive so I am starting from scratch . Thanks
Re: 65 Front end upgrade Brake line routing
I have some stock pics if that will help.
comes out of the tunnel along with the brake line & runs along the framerail before it goes outside the framerail at the wheel well area;
where it comes back in the engine bay near the front of the tire it is attached to the swaybar bushing bolt ;
Kingspeedy2
Thats a great starting point Johnno ,thank you
For some reason I had fuel line on my mind, :? :roll: . :? :roll: :roll: :?
I think I’ve got some before (stock) and after pics. Depending on where the connections are on your discs, you may need to move ‘em. I’ll dig ‘em up.
mine has a hole in the shock towers that the hard line goes thru. but you wont have towers.so you can choose where the hole will go. but I think the stock bracket area would be a good place for the junction to flex lines & a bracket pointing down seems to be the best way to go for either forward mounted calipers or rear mounted. There is a pic of Pop's relic here near the bottom of the page,kinda small pic but you can still see how they ran the lines ;
viewtopic.php?f=9&t=14924&start=60
his are also pointing down.
Kingspeedy2
thanks for the Link Johno ,it looks like Pops has the same kind of control arms as my Total Cost involved Kit.
