62 Shelby Drop
Matty
62 Shelby Drop
Post by Matty »
Guys, I've got a 62 Comet with the CSRP Kit on the front eith 65 steering. What template do I need? The one that offsets the holes back?(65-66 Mustang)
Got some new wheels also. 😎
1962 Mercury Comet S22 302 5.0 T5 Custom: tfs 1 cam & springs, 8.8 31 spline lsd 373 rear, 5 lug disc conversion front and rear, new V8 steering components, Gt40 heads, Performer RPM intake, phenolic spacer, Brawler 650
Re: 62 Shelby Drop
I got one floating around somewhere,I think. I sent it to comethead Joe. I'll pm him & see if he still has it, & to speak up here if he does. he can send it to you.
Matty
Re: 62 Shelby Drop
Post by Matty »
Thanks John. If I just new which one I needed I have the metal and abilities to just make one and save the effort.
Re: 62 Shelby Drop
If you can make your own, there're no lack of templates available.
https://www.google.com/search?q=shelby+ ... q6QbjsGNFM
Matty
Re: 62 Shelby Drop
Post by Matty »
Right...I just don't understand the difference between the two and which one I should use!
Re: 62 Shelby Drop
65-66 stang, or 1'' down,1/8'' back. any more than that & you would need the ball joint wedge thing, & unnecessary for street.
Re: 62 Shelby Drop
Matty wrote:
Thu Oct 08, 2020 9:38 pm
not sure which 2 you are referring to. there are 2 different templates for different years,if you scroll down to the bottom of this link there is a pic of both sets. later years had wider bolt spacing.
https://dazecars.com/dazed/drop.html
but there is another one which is maybe down an inch & a half & back a quarter, but it needs the ball joint wedge thing that re-corrects the angle of the ball joint. you can read about it some where on that dazecar link or opentracker racing. lots of other good tips in there similar to the shelby drop that will help your car drive better,more like a shelby. some are free,just labor. like the ball joint slide,.100'' offset UCA shaft & 1'' perch move.
Matty
Re: 62 Shelby Drop
Post by Matty »
