Wanted: 1965 Comet bell crank linkage that mounts to intake mainifold for a 289 c-4 automatic
Wanted: 1965 Comet bell crank linkage that mounts to the top of the intake manifold to carburetor with the setup for kick down for a 289 c4 automatic. I have the kick down rod that goes to bell crank to tranny, just need linkage off manifold. Thanks
Re: Wanted: 1965 Comet bell crank linkage that mounts to intake mainifold for a 289 c-4 automatic
If you aren't in a big hurry, I may be able to find one. The parts car is 20 miles from home and has a tree on it from Hurricane Laura. Had a 289 with C-4 in it, not sure the bellcrank is still there. I'll check at a convenient time and get back to you. Post, if you find one beforehand. Good luck!
Hi: JT
when you get a chance to see if it's there, I could use it if you have one. If there is a kick down on the parts car, I would be interested in that too. I could use it on another project car of mine.
thanks Rollin
thanks Rollin
